https://theairtacticalassaultgroup.com/ ... hp?t=26555TWC_Sp00k;285597]
The 1st TWC Forged in Iron event will take place in the TWC Tactical Server, GMT+0 2000hrs, next Sunday, 29 Oct 2017 (Australia)
There is a heavy requirement for Bomber pilots on both sides and accompanying Fighter Escorts to succeed
Forged in Iron
The scenerio is the German Army has just crossed the Somme river near Abbeville and are marching South! As a blue pilot you have to help your ground units achieve victory in the area.You will be called on 4 times in each mission to fly a special mission to destroy ground targets in the battle area and south of the Somme. If you fail to destroy these targets then the map does not move, the English have held you. If you do destroy the objectives then the map moves south and a new mission very similar plays out. no super planes E-1’s and E-3’s along with all the bombers VS Blennies, hurricanes and Spitfires of assorted types…. no Spit II’s .
As a red pilot you must stop the ground troops from advancing south. As a red pilot you have help in the way of dug in troops, armor and artillery. You have tanks on the way and must protect the assets you have in place as well as the ones moving into the area as well as harass any ground targets (trucks ,Supplies ,AAA, etc.) inside the front lines and across the lines when called to do so.Your fighters are useless against Heavy Armor so you need to spot for the bombers. You also will be called upon 5 times in each cycle to defend your territory against enemy air raids or to escort friendly bombers into the enemy territory. If you complete the missions or match the German output you have held them in place and the map will restart.If not the map will advance to the south and more german equipment will be put into the area making it that much harder to hold!
The enemy also has assets in the rear of there areas oil and fuel storage train transports Factories and ships and much more but it must be reconnoitered so you know where the target is located! Major areas have major targets but are well defended so Recon to find the target and tell your bomber buddies right where to bomb is a good idea. All buildings in the target area are live but if you bomb civilian areas your team will be penalized!!!!!
Destruction of fuel slows spawn of Armor destroy all fuel stores and all enemy armor slows to a crawl Death penalty is 5 min.You can still spawn in a tank, AAA, or gunner position but flying is restricted for 5 min. So don’t die! Stats reset after each death so you start on the bottom all over again.
There are over 3500 active targets on the map. The entire map is alive with the front lines moving to simulate the success of not of the battle!
Full details are at TWCCLAN.COM under the Tactical Server link. Maps of objectives for both sides also found here.
https://www.youtube.com/watch?v=LMbGrOoXkYU[/video]
Sign up for Squadron/Pilots for Allied and Axis Bomber and Fighter roles can be made in this thread.
http://www.forums.twcclan.com/viewtopic.php?f=74&t=4364
Look forward to seeing those of you who can make it.
Cheers.
http://twcclan.com/
