Posted: 14 May 2014 21:50
Vejam o lado positivo. Poderia ser Flying WITHOUT wings.
Enviado via MotoG
Enviado via MotoG
https://www.gavca.com/phpBB3/
O Boris'ight esta regulando, tentei bombardear um trem mas errei longe.Bomb sight for Pe-2, first implementation (a bit changed). It's recommended to use it during level flight
- Stats in MP., first implementation. Nations score and round rotation do not work. Personal stats are calculated properly however suggestions and particularly bug reports are appreciated
- Destroyed ground vehicles now can trigger explosions and damage of nearby objects
- Noise filter added to stick settings
- La-5, bug with taxiing at minimal of maximal revs fixed
- La-5, incorrect drag caused by flat wind screen fixed
- La-5, oil spils on the wind screen fixed
- La-5, intake fairing 3D model improved
- La-5, canopy framing 3D model improved
- Yak-1, fixed the bug that allowed to control the plane with ruddder shot off
- Pe-2, balanced the pitch oscillation
- Nav light graphics fixed for all planes
- The bug with plane parts hanging in the air (rudder, wings, etc.) fixed for all each aircraft except Pe-2
- Gun flashes (fire and light) are now visible on other players' plane in MP.
Early access week 24 update for tonight (not yet available)
http://forum.il2stur...access-week-24/
Acho que vou abrir um flame no Bo$pícioOps! Parece que tem o prisma sim.
http://translate.google.com.br/translat ... t_45.shtmlIn the view of the pipe is visible range (Fig. 283) with divisions corresponding divisions drum-arm from -15 to +75 °.
Condor, porque você não seta o botão 6 do segundo estágio do gatilho? Assim não tem que ficar fazendo malabarismo com o mindinho rsrs.28_Condor wrote:S!
Ué, mas que botão o cara usava para os canhões nos outros planes?
Tem um gatilho na base do WT (que é incomodo) mas que uso para os canhões...
Pois é, mas a "preguiça mental" é tanta que querem que no setup do jogo o La5 venha com o comando do canhãoLuisF wrote:28_Condor wrote:S!
