21_Sokol1 wrote:DHRF,
VKB already send a AIRROW as gif for you?
don't understand?
21_Sokol1 wrote:238$?![]()
Tá mais caro do que aqui.
Desse jeito os "negócios" do primo do Condor irão por água abaixo.
Se a VKB for atender os que os ruski estão pedido lá no tópico (de HOTAS F-1621_Sokol1 wrote:Mockup, sujeito a mudanças, do grip modern da VKB para "whistles" (Jet's, heli's, kosmosima):
In anticipation of the sample Gunfigher production lay out some information before the announcement.
Default Gunfighter will be equipped with KG12 (plastic) grip, which is also used in the Gladiator/Gladiator Pro joystick.
We continue to work on our new grip "Kosmosimov" (& whistles).
The work is still a lot, I hope we are on the right track.
If all goes according to plan, Gunfighter and Gladiator Pro will be platforms for the installation of the following grips:
- KG12 (this handle is already being used in the Gladiator/Gladiator Pro)
- KG12Pro ( KG12 metal version, the development of this grip is finished, but the mold has not yet launched)
- Handle Kosmosimov/(whistles) (under development)
- Copy (replica of some) number of grip for modern aviation (development will continue after the end of the work on the handle Kosmosimov).
You can use the grip of sticks from other manufacturers (via adapters):
-Thrustmaster Warthog (Cougar) (already made).
-Defender Cobra M5 (under development)
Adapters for grip from joysticks Saytek not planed.
Saitek product is bad for improvements.
Do not consider this post to be a VKB commitment. I just shared plans.
Great changes have taken place in the WKB, very much hope that the better. While more can not tell.
