Sokol1First impressions flying IL-2.
The joystick is very very smooth. UNTIL you travel thru center. There is such a change in movement pressure that snap shots may be very difficult. Otherwise the Warthog is a joy to fly with.
Ground pounding is very good, Boom and Zoom very good, Turn and Burn good, except for the abrupt pressure changes thru center. The MSFF2 is better, and now with the new G940 firmware its better, for turn and burn combat.
Se bem que:OK, some throttles died (do you have an ASUS motherboard? seems like those could be the problem in combination with the Warthog),..
Para os não iniciados na lingua de Shakespeare: Bricked = "tijolou".Informação da Thrustmaster:
"All Throttles that had this issue were having a computer with the ASUS P5 series mainbord, we have investigated this and developed a new firmware update."
Mine bricked on an Apple iMac! Go figure.....
S!21_Sokol1 wrote:
... Cougar no Frugalswolrd (RiP).
1. throw salt over the left shoulder
2. hang a magical horseshoe above your computer
3. try to eat french fries as to trick the hotas into thinking you are actually french.
4. use a unicorn horn to push the power button on the computer
5. never feed your hotas after midnight
Ok Cmte.21_Sokol1 wrote:DocFlyer, Que tal fazer um review deste Warthog, usando o IL-2 (que é o interesse da maioria aqui), mas um review obejtivo... o quanto o Wh melhora (se) o ato de colocar e manter o pipper do gunsight sobre o boggie. E por favor, faça o teste da espiral com o Joy Tester 2, estou curioso para ver como fica. Uma dica: ...suspeita que os casos do throttle "bricked" são devido a eletricidade estatica.
