Bombsight Table 2
Posted: 18 Jan 2011 13:13
Alguém está usando esse programa no Win 7 64? Não consigo fazer ele aparecer na tela do IL2.
https://www.gavca.com/phpBB3/
http://www.warbirdsofprey.org/index.php?topic=6965.0I wonder if you could try if Il2 Shturman is working for you http://navair.narod.ru/shturman.htm Looks like this: viewtopic.php?f=2&t=13463 You can set the controls like in BT2 so you do not have to learn too much...
Sokol1Overlay for OpenGL32
Everyone must know the problem of unemployed overlay opengl32 on the latest systems.
Found a solution, tested on Win7 x64, nvidia 196.21.
Game Overlay http://www.gameoverlay.com/
Need a little bit to adjust.
For example:
Run the prog, we want to see over the mud.
Run Game Overlay.
Status of the course should be active.
Tab Settings, remap buttons (default stand F8-F12).
Pose Shift-F8 --- Shift-F12.
Apply Settings.
Item Overlay Position, put the Custom and coordinates, such as 600 / 0.
Adv. Item Adv. Settings, Window Update Time - Settings, Window Update Time - any value to update the windows prog. Let it be 100 ms.
Sheds IL-2. Shift-F12 - on / off display window.
Shift-F11 - switch between running programs windows.
Click this button until you get to the desired program.
Use prog CPU time for these settings on the Process Explorer'u - less than 1%.
