Hurricane startup
Posted: 09 Aug 2012 02:29
Nesses dois últimos patchs ligar o Hurricane virou missão impossível
Mas graças ao Salmo temos o caminho das pedras:
My Hurricane startup procedure:
- fuel-cock switch on
- magneto1 on, magnito 2 on
- radiator closed (until engine warms up sufficiently)
- prop pitch to 0%
- throttle to 10%
- fire engine up, and should idle
- While warming up:
- Set mirror off (doesn't work anyway)
- Set gun sight distance & width 109's (42ft)
- Set compass (optional)
- turn gun sight illumination on
- turn on instrument ilumination (primary & secondary) if needed
- throttle up to 20% when engine temp > 40 degrees
- Keep radiator closed until temp > 60 degrees, then open rad's (warms up quicker)
- Prop pitch to 100%
- set rudder trim for takeoff
- ready to roll when engine temp > 70 degrees
- throttle up > 40%, (engine dies if throttle 20-35%, new game bug)
