VKB F-14 grip
Posted: 18 Oct 2019 19:17
Com é "norma" aVKB e VPC se imitarem, outro F-14'ish grip. Neste caso a VKB anunciou primeiro, mas a produção só para o final do ano, @ $189,00 (sem base):
Moldes para injeção plástica:
O grip tem até controlador próprio, de 32 bits.
Rubber inserts for a no slip firm and handy grip
Metal ammo switch, hat, and emergency autopilot disable trigger
Long travel soft click buttons
Modular hat design (fully dismantleable, all buttons user replaceable)
Ammo switch design based on contactless sensor
DLC maneuver wheel design based on contactless sensor
Two-step trigger design based on cam mechanism – similar to that used in real life war planes
Lockable contactless sensor twist mechanism
32-bit APM controller as the brain of the grip
