Re: BoS = IL-2 Sturmovik-Battle of Stalingrad - Desenvolvime
Posted: 20 Feb 2015 15:26
DD LXXXIX
O update 1.009 (one week) virá com o ME e o Dserver, console remoto, votação de missões, vote ban.
E curiosamente, fala sobre caracteriscas de "simulador" (oxigênio, arrasto do trem de pouso, flaps, ajustes no trim...) adicionadas ao game.
Fogo pode ser apagado "soprando".
Parece que o IL-2 do Condor ficou mais "tank" (18).
O item (45) deve ser igual ao Warbirds, nos servers com ícone pode-se destacar a cor do ala.
BTW - O Chuck_Coruja até "desemburrou", disponibilizou o download dos manuais novamente...
Se metade dos itens funcionar bem, sera um bom progresso.Next week we’re going to have a scheduled update V.1.009.
Along with pretty highly awaited dedicated server and full mission editor, fixes of sounds in multiplayer and several DM improvements, the update will feature the oxygen system simulation. I’ve asked one of our engineers, known as Gavrick on the forums, to tell more about this feature.
Every aircraft in BOS, except IL-2, is equipped with an oxygen system. It’s designed to provide normal breathing for a pilot on high altitudes. Flying higher than 3000m with a malfunctioning oxygen system or without one is dangerous due to chances of falling unconscious and lowered tolerance to overloads.
Soviet planes are equipped with KPA-3bis open type oxygen devices. He 111 have similar systems while all other German planes in our game have lung-governed oxygen feed devices. The first type delivers pure oxygen directly while the automated lung-governed systems mix oxygen with the surrounding air and feed it for breath-in only. Accordingly, such devices spend different amount of oxygen on different altitudes.
Oxygen is stored highly pressurized in special tanks. Every plane has a manometer to control the use of oxygen. Normally there’s enough oxygen to gain altitude and maintain flight on reached altitudes for a long time; some planes have so much oxygen on board that it’s basically impossible to spend it all on one fuel tank.
In case if the oxygen system is damaged it is highly recommended to avoid high-g maneuvers and descend to 3km and lower.
Well, here it is, the full change list that describes the up-coming version 1.009 which you’re going to get early next week:
1. Oxygen system added. In case when it’s damaged or when runs out of oxygen, the pilot will suffer more severe overloads on high altitudes;
2. Fixed rudder wobbling when control rods are broken;
3. The stick doesn’t wobble when shooting any more in a plane parked with its engine off and at calm weather;
4. The bounce of the stabilizer that used to bother pilots tuning (trimando) it for Bf 109 was fixed;
5. Default yaw trimming for Yak-1 was fixed; the plane is now trimmed for combat flight speed;
6. The approach to default roll and yaw trimming changed: it is now working as trimming with rods that should return to combat speed position when released to neutral position;
7. Fixed tabs on Bf 109 and Fw 190 were tuned so that the default stabilizer position is now more convenient;
8. Yak-1 and IL-2 flaps are now influenced by the incoming airflow as the speed increases (at about 250km/h).
9. Landing flaps can now stuck or break off at speeds that exceed the normal speed which these elements are supposed to withstand;
10. Plane is now shaking and can get it’s landing gears broken away when flying at high speed with the gears down;
11. Open bomb hatch should now affect the air drag;
12. Flap control lever on Yak-1 was fixed: it should not be shaking at high engine revs and should not return to neutral position when the flaps are down;
13. Fixed the issue with engine not starting at all after a failed attempt to start;
14. HE and fragmentation ammo influence on armoured elements fixed: they are now properly protected from low caliber hits;
15. Armour penetration ammo has also been more precisely tuned;
16. Ground crews are now running away correctly from exploding vehicle;
17. An issue with ground vehicles placed near each other not exploding in Multilayer was fixed;
18. Airframe durability has been tuned and increased in most of the cases adding more resistance to direct hits;
19. Fixed abrupt blackouts that pilots of Bf 109 experienced when using flaps while the slats are out;
20. Fixed abrupt blackouts when putting up the gears right after takeoff;
21. A rolling gear wheel aerodynamics fixed. This should decrease the chance of nose over and as a result make landing a bit easier;
22. All radial engines in the game got their durability incresed;
23. An opportunity to extinguish fire in the fuel tanks on flight. To do that increase speed and sideslip;
24. Gun spread was recalculated. German fixed weaponry got horizontal spread decreased by 50%;
25. MG/FF cannons on Fw 190 A-3 and He 11 H-6 got their horizontal spread decreased according to the reference;
26. Horizontal spread of turret guns in case of overheat has been increased;
27. Several Campaign and Dserver crashes have been fixed;
28. AI bombers should now correctly drop the bombs after the Do Like Me command;
29. AI will not bail out instantly but with a random delay;
30. Significantly improved the situation with hit sounds in Multiplayer;
31. AI stay in formation when an enemy fighter is spotted;
32. Invisible tracers fixed in Multiplayer;
33. AI dive bombers Ju 87 and Pe-2 will do vertical dive bombing only if the need to spend not more than 2 minutes to gain the necessary altitude; next dives the do will be flat ones;
34. AI should now return to the home base if damaged or leaking fuel;
35. AI that go to home base because of low ammo or minor damage should now be going on max speed;
36. AI that was damaged, or has low fuel or zero ammo will now perform evasive maneuvers on its way to the home base;
37. Light BT-7M tank added;
38. La-5 canopy framing was slightly corrected;
39. In Campaign and Quick mission, a transport convoy will move off the road and spread if attacked from the air;
40. Full player list on the server added;
41. It is now possible to vote to kickban a player (for 24 hours by default);
42. AI controlled Ju 87 are now using flaps correctly on takeoff;
43. Excessive wobbling on roll axis that appeared during dive maneuvers on Ju 87 was removed;
44. AI planes will start engines again if they fail to do that at first attempt;
45. It is now possible to mark players on the server; marked players have purple icons;
46. Ground target markers are now shown on all the objects, not their group leaders only;
47. Distance is now shown on markers of ground targets (3km and less for group leaders and 1km for each object);
48. Full mission editor added <game_folder>\bin\editor\STEditor.exe;
49. Dedicated server added <game_folder>\bin\game\DServer.exe;
50. Remote control console for the dedicated server added <game_folder>\bin\console\;
51. It is now possible to set a pool of missions to put the to rotation on a ranked server. To add a mission to the pool you need to contact us;
52. Interactive Flash scenes and pictures can now be added to custom mission design.
53. HUD is now turning red when the plane is near stall, or suffering from flatter;
54. Ranked server are now marked with red badges in the server list;
55. AAA should now cover transport convoys in Quick Mission;
56. Snowy ground textures improved;
57. When the bomb hatch is open the wind noise can be heard.
