![Image](http://img543.imageshack.us/img543/2261/109slats.jpg)
Sokol1Added detailed DM for fuel tanks.
When a tanks is hit the fuel start leaking from this particular tank only.
Groups of tanks in the fuel system will be implemented later.
Slats
Engines won’t start automatically after a stall.
Overheat can occur before take-off, in the air on low speed and in WEP mode as well.
Sokol1I just downloaded the latest update of the beta game.
And I must say I was astonished by the beauty of the Stalingrad map.
First time I see a map in an aviation simulation which looks almost real!
After that, impossible to play on another sim, without saying: "mehhhh"!
I must also insist on the absolute beauty of the clouds and the light just under
or just above the clouds, the feeling of "being there".
It seems also they have toned down the "save the private Ryan" filter,
what is a very good thing.
Frankly, this game engine is a marvel and the textures and clouds guys are top.
I just hope too that the Gaijin studio will realize that they have a marvel in their hands, that means they have
the perfect sim as a possible target, if, yes IF they go on the path of realistic FM's and game modes also
without "airquakers" features.
Uai, então eles não tem um magnifico engine de simulador, mas um magnifico engine de um FPS voadorif, yes IF they go on the path of realistic FM's and game modes also
A verdade é que os numeros de jogadores conectados ao WT dizem que este é o modelo "certo". Vide "caça níquel" do World of Tanks, o dono vai até fazer expedição atrás dos "Spitfires perdidos" da Birmania.Spent my first 25 bucks on 5000 Eagles, best thing I did as now my English planes are nicely upskilled, enough to give some pain to some of the more aggressive Ruskies.
There's no doubt that you need to keep the premium membership going to keep up good progression.
Now I don't play every day, so if I buy a daily pass it's only 50cents.
Really, not much, equivalent of a few good fsx or xplane addons, but I know what platform I'd be spending more time FLYING in!
O cara que escreveu isso frequenta o forum da Gaijin, e tinha aberto um tópico pedindo mais "IL-2" no WT, mas não a muita esperança."I'm a bit pessimistic. Presently even the possession of a joystick is being attacked as elitist and the so called 'full real battles'
(which are not so full real btw) are under siege by a crowd that's demanding icons and mouse aim for every game mode."
