Versão 4.13 do il2 1946 já saiu!
Posted: 05 Jun 2015 14:23
https://www.gavca.com/phpBB3/
Caso alguém queira reinstalar o jogo, link para todos os patchs anteriores:New AI planes
Aichi E13A floatplane
He-177 A-3
Ju 88 A-1
Ju 88 A-5
Ju 88 A-6
Ju 88 C-2
New Flyable Planes
B-24D-140-CO
IK-3
Ju 88 A-5 Late
Ju 88 P-1
N1K1-J
N1K1-Ja
N1K1-Jb
SB 2M-103
New plane external models
P-40E (with 17 default skins)
P-40E M-105 field mod.
New ground units
2cm Flak 38 Vierling
Skoda Pa.II 'Zalva' armored car (MG and radio version)
Jagdtiger
M10 tank destroyer: early and late (late comes with closed and opened hatch)
M36 tank destroyer with closed an opened hatch
Type 94 tankette (Japanese)
US AA trailer (quad cal50)
Regimental Gun 76mm
ATG 45 mm (1942)
Soviet river gun boat Smolensk
New features
Total overhaul of most bombsights
Added new 'realistic bombing' difficulty option to toggle between realistic/simplified
bombsight inputs
Bomb release mode keys added
New bombardier & co-pilot position that can be manned in online coops
Added momentum from asymmetric bomb loadouts
Rocket release mode key added
Course autopilot added to Luftwaffe planes
Added working PDI lights (red, green white) to many Russian bomber pits
Ordinance camera added
Added target height to minimap ground targets
Added gunner's multifunction key. Used for opening hatches, canopies, raising & lowering
guns.
Added gunner reloading if gun has magazines
FMB showing proper skin of ground objects depending on the World.camouflage
Added FMB scrolling between different units in object windows for chiefs
Added bombardier cockpits for all Pe-2 variants
Added QMB option for player to chose his position in the flight
New IJA, IJN, Dutch, USN & USMC regiments
Added Icon settings to GUI Misc
Added option that Icon range can be shown in meters or feets
Added differential brakes
Added over 100 new loadouts for Russian planes including RRAB cluster bombs and flares
Bomb loadouts added to Doras
New loadouts added to Ju-88 A-4
New rear gun station added to Ju-88 A-4
New 3D meshes for some British bombs
Added new conf.ini option Use3RendersUI=1 that will render UI with 1/3 width.
Added new misc option for rendering info HUD at the bottom of the screen.
New map
New Britain & New Guinea (September 1943)
New Britain & New Guinea (June 1944)
Svalbard
Tobruk
Slovakia Autumn
(Late autumn season. For proper look, it is recommended to set
parameter Forest=3 in the conf.ini file under the [OpenGL] section.)
Map fixes
Normandy
Bridge E of Eterville village fixed
Houses on the railroad removed in the Eterville village
Kursk
Number of bridges and crossings fixed
Kurland
Fixed couple of bridges and one stay/taxi waypoint near Libau
Italy_DF
Missing railroad east of Napoli finally constructed
Kiev
Rail/road crossing south of Ovruch fixed
Country bridge east of Ovruch changed to correct railroad bridge
Kurland
3 country bridges added southeast of Goldingen
Rail bridge near Rosne changed to correct country bridge
2 missing highway bridges east of Schaulen built
Moscow
Bridge south of Povarovo changed from country to railroad
Smolensk
Bridge northeast of Gorodok running over meadow removed
Rail bridge west of Mstislavl changed to country bridge
New missions & campaigns
Updated Coral Sea QMB missions
RU campaign
La-5FN "Uprising 1944"
I-16, I-16bis, I-153 "Khalkhyn Gol 1939"
DE campaign
Ju-88 A4 "North bomber"
SK campaign:
B-534 "Little War"
B-534 "Polish campaign"
SK single missions
B-534 "Little War" (7 missions)
B-534 "Polish Campaign" (5 missions)
Bf-109 G6 "Last fight" (1 mission)
La-5 FN "Uprising" (9 missions)
US single missions
B-24D-140-CO "Anti-Submarine Hunt" (1 mission)
New skins
5 new SM.79 default skins
5 new Tempest default skins
27 new P-47 default skins (USAAF, RAF CBI, USSR)
100+ user skins (BMP)
Other fixes & tweaks
Fix for the "FM" bug that can cause wingless plane to fly normally
Fixed FM bug that caused two separate flights crash after certain plane was removed from
formation
Fixed bug with engines that caused RPMs to increase rapidly when engine selections were
changed
Fixed IL-4 engine DM bug that would cause left engine damage when right engine was shot
Fixed very old online bug that caused wrong visual animation of engine states (with 2 or
more engines)
Fixed bomb delay bug. Old style delay (without fuzes) was not staying on UI
Engine DM tweaks for Spit, P-51, P-47 & P-40. Added missing bullet energy reductions and
tweaked damage probabilities
New Ho-3 cannon belting
Fix for AI taxing takeoff bug in coop
Engine DM fix so that pilot doesn't get BBQed if engine is behind pilot
Increased minimum alive time of many MG & cannon rounds
Fixed player taxing bug with autopilot
Fixed NTRK & bomb bay door bug that caused doors to randomly close during playback
Fixed beacon selection bug
Added missing Emily nose cap
Fixed Ki-43 nav lights
Fixed B5N FM bug that caused AI to fail torpedo run if waypoints were set too high
Adjusted the negative G limit when redout is starting to happen
Changed the stock “loiter here” order so that it can be issued to player's own flight so that
other planes stop following player.
Removed old bomb explosion randomization that might leave unit close to explosion alive
and kill another unit much further from explosion
