http://theairtacticalassaultgroup.com/f ... hp?t=22393-Major consequences for dying or being captured (can't fly again, but can operate ground objects).
-Minor consequences for bailing out or being injured (timeout dependent on how long you bleed).
-Escape chance scales to how far behind enemy lines you are (but always retains a slim chance).
-Pilots downed behind enemy lines can be rescued by nearby friendly ground forces.
-Pilots who crash-land behind enemy lines can be rescued by another player conducting a rescue flight, which is highly rewarded.
-Mission scoring is essentially currency, which is only good if it is traded in for the ability to produce more war materiel.
-Refineries produce fuel (on columns).
-Factories manufacture aircraft, tanks, artillery, AAA, as well as supply columns filled with ammunition, bombs, and repair kits.
-Shipyards make cargo ships and escort vessels.
-Power plants influence the production capacity of the other industrial sites.
-Cargo ships transport ground forces and supply columns between ports, or conduct amphibious landings with numerous small craft.
-Players can make supply flights to distribute resources in real time.
-Airfields and industrial sites represent territory control points to be captured, or they can be bombed to deplete enemy resources and industrial output.
CloD - Ghost Skies Dynamic Campaing Online
1 life per mission. Engine baseado no HRCODWAR (baseado no SNAFU).
