Sokol1IL2: Cliffs of Dovers DRM solution
Posted on 7 March 2011 by admin
Hello,
We received many questions about the Digital Rights Management solution used in IL2 : COD. we understand it is an important subject for many of you, and we are a glad to tell you that IL2 Sturmovik: Cliff of Dover will use the SolidShield DRM solution. SolidShield features a flexible activation process and allows for up to 3 simultaneous game installs.
Please note that the game will also use the Steam platform for services such as matchmaking, anti-cheat etc… So you will need a Steam account to play the game.
Please refer to the Q&A below for further clarifications on Solidshield integration.
What type of DRM is being used in IL-2 Sturmovik: COD?
Avatar uses a new driverless activation solution to manage activations developed by Solidshield with whom T@GES is partnering.
How many activations do I get?
You can indefinitely activate your copy of the game on the same PC. You start with three activations (so, three different PC hardware configurations) to begin with. After one month, one activation will be re-credited (up to a maximum of three available activations at any given time).
Do I have to be online to activate my game?
While the activation solution will initially attempt to activate your game online, you can elect to manually enter an activation code. You will need to enter the code that comes with your game into the activation wizard, you will then be given an activation code that you can enter manually. So, although you do not necessarily need to have your computer hooked up to the internet, you will need to go online to obtain a code before playing.
Can Solidshield be removed from my computer?
Once the activation process has been completed, the activation solution does not install any software on your computer. Once the activation is completed, a data file is stored. This file is not hidden and can be removed from your computer if you wish. In this case, a new activation process will be triggered at the next game launch (without any effect on your activation count credit). Finally, the activation is driverless: no driver must be installed and uninstalled.
What if I have problems?
You may contact Solidshield support directly via email at [email protected].
Is it possible to revoke an installation?
Revocations are not considered, since users get one new activation per month, so if you do somehow manage to burn through your three activations, you only need to wait one month or contact support.
http://il-2-sturmovik.ubi.com/cliffs-of ... uk/?p=1162
STEAM
STEAM
No samba de criolo doido que a UBI vem fazendo como CloD anunciaram que o DRM mudou (a "two weaks"
da data do lançamento...), agora é o SolidShield e que para jogar online será usada a plataforma STEAM:
- VF-1_BRAVO
Re: STEAM
Gostei da noticia.. jogo alguns jogos pela steam e, particularmente, não tenho o que reclamar... comprei o black ops pela steam e foi show de bola... ja sei onde vou comprar o CLOD
OBS: Espero só que os servidores sejam dedicados..e nao aconteca como era no COD MW2, onde vc entrava em um estilo de jogo e esperava abrir um server qualquer...
abraços
abraços
- 07_Phantom
Re: STEAM
Alguns pontos positivos disto:
70% do valor do game vendido pelo Steam vai para o produtor (distribuidoras cobram 45/50%).
O Steam é um ótimo divulgador dos games. Muita gente comprou o 9velho) IL-2 porque colocaram no Steam.
Sokol1I had never heard about IL-2 before I got Steam and look at me now.
Re: STEAM
Verdade. Eu só pude comprar pelo Steam também.
Antes, além de ter que esperar mais de 30 dias, ainda tinha que comprar o DVD do IL-2 pelo valor que o camarada exigisse.
Re: STEAM
Meu vicio comecou com um CD do IL2 que sorriu para mim da estante da kalunga por onde eu passava pensado em outras coisas... como todo vicio, a primeira dose sempre é fácil, mas depois o fornecedor fica fazendo cú doce, entao, a cada lancamento de um incremento na minha droga, tinha cada vez mais dificuldade de conseguir meu CD, até importar a muamba tive que fazer...
Gracas a Deus, agora vai ficar mais fácil
Re: STEAM
Mmm, o SolidShield usa o STEM para controlar o jogo, então para jogar OFFLINE é preciso ser pelo STEAM.
Important:
The Steam client application's files must be updated to allow for the use of Offline Mode. If your game's status is "100% - Ready" but you receive the message "This game cannot be started in Offline Mode" when attempting to play offline, the Steam client application's files need to be updated.
Foi-se o tempo que bastava instalar o IL-2 uma vez, fazer uma cópia, modar, bagunçar, formatar e nem precisar reinstalar tudo de novo...Using Offline Mode on a PC.
Please follow the instructions below to configure Offline Mode on your PC:
1. Start Steam online - make sure the Remember my password box on the login window is checked
2. Verify that all game files are completely updated - you can see the update status for a game under the Library section (when the game shows as 100% - Ready it is ready to be played in Offline Mode)
3. Launch the game you would like to play offline to verify that there are no further updates to download - shut down the game and return to Steam once you have confirmed that the game can be played
4. Go to Steam > Settings to ensure the Don't save account credentials on this computer option is not selected
5. From the main Steam window, go to the Steam menu and select Go Offline
6. Click Restart in Offline Mode to restart Steam in Offline Mode
- VF-1_BRAVO
Re: STEAM
Skol, acho que a questao offline é tranquila.. eu particularmente joguei pouco offfline. quando jogo uso apenas para treinar dog..... a minha duvida é saber como sera a parte online..os servidores serão dedicados ou não? vc tem alguma informacão sobre isso?
Re: STEAM
Em algum post aí embaixo fala-se de DS, como no IL2...
- 07_Phantom
Re: STEAM
Na verdade ainda é possível, o steam verifica os arquivos, se tiver uma cópia ele checa e baixa/"instala" apenas os arquivos necessários.21_Sokol1 wrote: Foi-se o tempo que bastava instalar o IL-2 uma vez, fazer uma cópia, modar, bagunçar, formatar e nem precisar reinstalar tudo de novo...
- VF-1_BRAVO
Re: STEAM
só uma pergunta..sera que o HL vai morrer para o clod?
Re: STEAM
Pelo jeito não vai nem nascer para o CloD.
IMO - O IL-2 sobrevive até hoje devido ao HL, se dependesse daquele browser da UBI que vinha embutido nas primeiras versões já teria virado "história" a tempos...
- VF-1_BRAVO
Re: STEAM
21_Sokol1 wrote:Pelo jeito não vai nem nascer para o CloD.
Skol, isso é a única coisa que realmente me preocupa em relação a STEAM.... será que os servidores serão dedicados?
Re: STEAM
O HL não tem nada a ver com servidor dedicado.
Ele serve apenas para facilitar na procura por servidores na internet.
Você pode criar um servidor dedicado ou um comum.
Caso o IL-2 viesse com uma interface parecida com a do Half Life para jogos online, nem seria necessário o HL.
E parece que é isso que vai acontecer.
Mas eu ainda acho que o HL vai dar um jeito e se adaptar ao novo IL-2 (1940
), porque o HL nada mais faz do que chamar o executável do IL-2 enviando as opções que você escolheu e o nick da sua conta para facilitar nas estatísticas.
