Patch 4.11 lançado! + Fix + 4.11.1
Re: Patch 4.11 (WiP) - atualização:
Atalização do 02/11:
http://forum.1cpublishing.eu/showthread.php?p=249644
General overhaul of AI-behaviour
The following video gives a first impression of a lot of subtle or major changings we have done on the AI, so that it is behaving more like human players - so it is more comprehensible, more unforeseeable and more varied.
Thus it also will become a bit more challenging. This video shows the differences in aiming abilities between patches 4.11 and 4.10.1. More details will come soon.
Opa, um Mosquito novo:
Mosquito FB Mk. XVIII 'Tse Tse'
Deram também uma boa retrabalhada nos settings de dificuldade :)
Heero
Post by Heero »
ja vejo o futuro!
"impossivel de pilotar contra as I.A.'s".
Por algum motivo colocaram esse patch em banho-maria, não é possivel que esse atraso todo seja técnico :^)
Estava esperando esse patch para me animar a voar de novo o IL2 (Pe-8, IL4, novo Mosquito, IAs bravas...) :|
Atualização 26/11:
Gunners IAs amigas em vez das "mui amigas":
O cenário do deserto vai ganhar novos tanques :)
Mas estimativa de lançamanto, nada :?:
Mais devagar que patch do CLoD :P
44_Santo
Post by 44_Santo »
Parece que vai sair:
daidalos.team wrote:We are planning to release the patch within this holiday season.
daidalos.team wrote:Main Features
• 6DoF support with over 100 fixed cockpits
• AI improvements
• Improved radiator & overheat modeling
• Difficulty option changes
• Bomb fuzes
• Stationary plane spawning
• Reworked bomb damage
• Control surface & pilot's head positions transferred over network
• Mouse wheel zoom
• Bombing commands
• Additional waypoint parameters
New Flyable Planes
• PE-8
• TB-7 M40
• IL-4
• Fw 190 A-4 1.42 ATA
• Mosquito XVIII "Tse-Tse"
New AI Planes
• TBD-1
• Hs 123
• IK-3
• Cant Z 506B
• Ki-45 Kai Hei
• Ki-45 Kai Tei
New ground units
• Autoblindo AB 41
• Carro Armato L6-40
• Carro Armato 13-40
• Semovente 47-32
• Semovente 75-18-40
• Crusader III
• Several new groups and companies based on existing tanks & vehicles
http://forum.1cpublishing.eu/showthread.php?t=28663
Mal posso esperar... :rock:
NiltonAC
Post by NiltonAC »
Finalmente 6dof...
A conferir o FW-190 ATA 1.42. Talvez me anime a voltar ao IL2...
[],s
Ronin / Roedel / nacard
O uso do radiador fica mais complexo, até a temperatura do mapa influência. :)
4.11 introduces a more detailed and more accurate radiator model. It is different from the
previous model in many ways, the main differences being:
• radiator settings now have an impact on both water/cylinder and oil temperature
• outside temperature now has an impact on oil temperatures
• engine rpm has a bigger impact
• impact of WEP is dependent on extra power generated
• mixture setting has an impact
• the density of the air has an impact
• aircraft speed has a bigger impact
• there is no longer a fixed period after which damage occurs in case of overheat
• introducing a random chance for damage depending on how strongly the engine
overheats
• type of damage is depending on if it is water/cylinder or oil overheating
You will generally find that the planes overheat a lot more, in particular if you are not on a cold
map in fast level flight. As a guideline, on hotter maps you can expect fighters to be able to
sustain about 70% power at 70% pitch without overheating radiators closed, for bombers it is
somewhat more. The values in many cases are reasonably close to real life maximum
continuous settings (please don't go by cockpit gauges, they aren't always accurate).
If you start a low speed full power dogfight with a closed radiator, you can expect the engine
to overheat rapidly and to get damaged quickly. War emergency power settings should
therefore only be used in an emergency, otherwise your plane might get destroyed without
your enemy even firing a shot.
To keep engine temperatures low, remember:
• use low rpm (reduce pitch), in particular oil temperature are sensitive towards rpm
• use low throttle settings (and avoid WEP)
• open the radiator
• fly faster (don't climb at too low speeds)
• use an as rich mixture as possible
O "6DOF" esta até bem implementado - considerando o engine "véio" - a retícula do gunsight não anda pelo parabrisas com em certos MOD's.
SOkol1
Esse "6DOF" funciona com o FTnoIr?
44_Santo
Post by 44_Santo »
Certamente, Condor! ^_^
IA
Various new AI maneuvers have been added. Number of maneuvers is increased by 25%.
AI planes will no longer detect enemy planes automatically inside certain radius. Position and
size of enemy plane is the main factor here. Bigger plane will obviously produce a bigger and
more visible "dot" and it will be more visible to AI.
AI skill will generally determine how well AI can spot targets. Also every gunner on board will
contribute to enemy spotting by covering their own sectors.
Generally pilots will keep looking more forwards than backwards. Occasionally fighters execute
fishtail maneuver to get better view behind. Planes will be less visible against dark background
like land, but more visible against brighter background like sky and clouds.
Clouds & land mass blocks AI's ability to see other planes behind them. For example it is
possible to evade attacking AI plane by hiding in clouds. AI planes will also try to hide in clouds
in certain conditions.
AI's own plane will block their line of sight. This is calculated from the plane's collision model.
For example basically all planes cannot see directly below them, unless the plane has
ventral/bottom gunner that can cover the underside. For example plane like Blenheim has
blind spot rear & behind since it has no tail/bottom gunner. Plane like B-17 with bottom/rear
gunners cannot be surprised from rear & behind like Blenheim (during daylight).
Occasionally fighters will execute roll maneuvers to get a look directly below them.
When fighter is pulling positive G's to get a lead shot and target goes invisible under nose, AI
will not see the target. Instead of aiming at the actual target, AI is shooting at estimated
target which position is extrapolated based on the last real observations. Much like human
brain would do.
AI pilot's ground collision detection is improved and now they will detect ground obstacles in
front of them better. Previously AI always crashed into certain kind of hill/mountain which has
too steep slope.
Environment factors such as darkness affects how well planes can be seen. AI is blind against
attack from sun and planes show up better as silhouette against moon. Planes are spotted
more easier if they emit smoke, fire, condensation trail or have lights on or are illuminated by
searchlight.
Also ships & ground AAA and aircraft gunners have the same clouds/ground/environment
restrictions as AI pilots.
AI gunners check before shooting that there is no friendly planes in front/behind their enemy
target.
AI gunners don't keep shooting while the gun is turning towards target and the target is
nowhere near when the bullets would go. So gunners will no longer waste ammo for stupid
shots.
Gunners will be less accurate shooting targets that move fast. In other words target that
forces the gunners to turn guns fast is less likely to get hit.
Gunners that experience too much positive or negative G's cannot fire at all.
AI plane's engine will overheat forcing AI to reduce throttle and open radiators.
AI planes respect diving limits of their planes.
Changes have been made in AI deflection shooting. AI calculate deflection better but it is still not perfect. AI's ability to chose correct deflection and to hold steady aim vary with the skill. AI
Aces shooting ability is now at human aces level and if they get into your close six you will be
in trouble.
AI flights doesn't go into attack as soon as they spot the enemy anymore. Depending on the
situation AI might try to avoid fight or try to improve their position before commencing the
attack.
AI skills are now divided internally into sub-skills and thus provide finer distribution of skill.
Aces are still better than Veterans and Averages are better than Rookies but not all AI pilots
with the same skill are the same. Some fly better, some shoot better. Some are braver and
some see better. This makes their behavior less predictable.
In addition to the maneuvers, AI fighter defense is completely reworked, no more constant
rolls. AI will perform diverse maneuvers and provide bigger challenge to the player.
AI will make mistake too. They will stall and spin occasionally, panic and “freeze” and
sometimes they will even bail out before you fire a single bullet at them.
44_Santo
Post by 44_Santo »
Maravilhoso, para quem voa muito offline como eu, é um sonho se tornando realidade. :rock:
É legal também online, já que as IAs colocadas no AW são mais desafiadoras :)
Furias
Manicaca
Manicaca
Post by Furias »
1) nova modelagem dos radiadores : adeus voar de 109 g-2 com 105 % de potência sem superaquecimento...RSSSS
2) novas IA : aguardando no AW.
Changed bomb/torpedo logic so that they do damage online even if “owner” dies before
detonation
Esta mudança vai criar uma nova geração de "kamikases"... :p
detonation[/quote/
Pode ser, mas o outro modo não era realistico, e não recompensava o esforço de se acertar o alvo :)
A pontuação, porém (espero), não deve ir para o jogador, porque seria uma recompensa "post mortem" :P
