https://forum.il2sturmovik.com/topic/63 ... comms-app/
O Text to Speech pode ser usado para dizer qual é e canal de rádio sintonizado quando usar o comando "Next channel" e "Previous Channel".New IL2-SRS Version - 1.0.0.2
This release adds an Installer and Auto Updater. The installer will automatically add the "telemetry" configuration required for SRS to work with IL-2. Just select the game directory and let it do its thing - no need to edit anything.
If you do have issues - follow the first post of this thread for the manual method of editing the startup.cfg
Just run the Auto-Updater or download the release zip IL2-SimpleRadioStandalone-1.0.0.2.zip - extract and run the installer.exe
Changelog
Added Text to Speech volume slider
Added Auto Updater
Added Installer with shortcut creation
More details and release here: https://github.com/ciribob/IL2-SimpleRa ... ses/latest
O "Text to Speech" agora tem um botão para reportar o status do rádio, qual canal selecionado, quantas pessoas no canal...Changelog
Added second radio - controllable server side. By default 1 as before
Added channel control limit to the server - 5 to 25 available. By default 5 as before
Added new TTS status read out
Bug fix for channel 1 on launch
Bug fix with saving TTS volume
Servers and clients will need to update to enable the second radio and extra channels
New control bindings for the second optional radio
O SRS do Box - que é mais simples; é diferente do SRS do DCS, se é isso que esta perguntando.Tem que instalar um app para cada jogo?
