ForceWare for NVIDIA GeForce GPUs
If you want the ultimate 3D performance and stability for all your games and the highest video quality for multimedia applications.
ForceWare for NVIDIA nForce MCPs
If you want high-speed system performance, unparalleled secure networking, and advanced storage solutions for maximum system scalability, functionality, and versatility.
ForceWare for NVIDIA GeForce Go GPUs If you are looking for gaming on the go, long battery life with great system performance, or a notebook PC to drive your home-theater experience.
Advanced Display Timing Options
Gives you the ability to adjust timings for your graphics card in order to support a variety of different display timings found on consumer electronic televisions and projects: ultimate flexibility for analog CRT and DVI connections.
Application Profiles
Application profiles, part of the NVIDIA® ForceWare™ graphics driver, allow you to quickly create custom image quality and performance profiles for all of your games and applications. For instance, you may wish to run the latest car racing game at the highest levels of image quality for antialiasing and anisotropic filtering. Or you may to run your favorite action game at the highest speed possible. You can even set global settings for all of your applications. With NVIDIA’s graphics profiles you can easily manage all of your games and applications. Once you have set up a profile, it will automatically change the settings when you launch the application for that profile.
NVIDIA nTune Performance Application
Previously known as the NVIDIA System Utility
The NVIDIA® nTune™ (version 2.5 of the NVIDIA System Utility) is the easiest, fastest, and safest performance optimization and monitoring application available for your PC. Incorporating more features than any other system tuning or monitoring product, NVIDIA nTune(*) is the only performance tuning application designed exclusively for your NVIDIA nForce-based PC. With NVIDIA nTune your system can automatically adjust to maximum performance settings for intense gaming or will detect that you’ve inserted a DVD and will set the system to quiet operation. This intelligent application offers the safest way to change bus speeds, memory timings, and even tweak voltages. Changes are made easily within a simple-to-use Windows interface--so you no longer need to make changes to the BIOS or reboot your system.[/b]
