Path 4.08
- 32_Mariocar
- Engrenado
Path 4.08
Estão anunciando a liberação amanhã no SimHQ Forums
http://www.pacific-fighters.com/en/home.php?skin=S2
README
Il-2 Sturmovik: 1946
v.4.08
Warning
The current version 4.08m is not compatible with the previous versions of the sim when playing over the network (Online). Both the server and client must have the appropriate versions in order to connect.
Attention: Verison 4.08m is only for a merged version of the simulator of the proper version (FB+AEP+PF)
The Il-2 1946 add-on v.4.08m installs only over v.4.07m (1946 DVD or FB+AEP+PF+46 merged).
In order to install this add-on, run the file 408m.exe and follow the on-screen instructions.
Please note that this add-on is impossible to install over stand alone Pacific Fighters.
Corrections:
-Updated the J2M5 Artificial Horizon;
-Modified the Ta-183 Variometer;
-Updated the MiG-3 Landing Gear Indicator;
-Corrected the brakes animation in the LaGG-3 and Yak-1 / Yak-7;
-Updated weapons and ammunition types on the He-162C/D, Yak-15, N1K2-Ja, P-63C, CR.42;
-Modified the retraction of the tailwheel on the N1K2-Ja;
-Corrected the brakes on the N1K;
-Updated the Il-10 Fuel level indicator;
-Updated the trigger animation on the Ki-43-IIKai, N1K2-Ja;
-Modified instrument panel damage on the Ta-183;
-Updated rudder animation on the Lerche-III;
-Updated the Yak-15 compass;
-Modified the canopy framework on the N1K2-Ja, both internally and externally;
-Corrected the armored seat back on the MiG-13 and I-250;
-Modified the FAB-1000 bomb position in the A-20C bomb bay;
-Updated trimmer indicators on the J2M5;
-Updated trimmer indicators and controls on the Ar-234B;
-Modified damage model of the Ki-27 wings;
-Corrected distances in the K-14 gun sight;
-Corrected the J2M5’s altimeter;
-Updated the flap sounds on the Pe-2 series;
-Changed Il-10 rear gunner compartment sounds to an “enclosed cabin” type;
-Corrected Ki-27 flap sounds;
-Decreased the volume of certain ground-based guns as heard in the cockpit;
-Modified Ta-183’s AI routines;
-Changed parameters for the Ta-183, Me-262HG-II, Lerche-III, Bf-109F-2, MiG-13/I-250, Yak-3R;
-Updated Object Viewer data for the Yak-3R and A-20C;
-Modified the MG42;
-Updated the in-game credits;
-Fixed errors in loadout names for certain planes;
-Fixed the A-20C crew error;
-Updated the canopy damage model on the MiG-9;
-Fixed the MiG-9 artificial horizon;
-Modified the engine shut-down parameters at low altitude for the MiG-9 (I-300);
-Fixed the ground clipping on MiG-9’s landing gear;
-Updated animations for the landing gear, flap and gear levers, bank indicator, and pylons on the Ta-183;
-Fixed Lerche-III fuel level indicator;
-Il-10’s ShKAS ammo load set to 2x750;
-Removed the duplicated loadouts on the I-153P;
-Fixed tracer colors on the Ki-43 and Ki-61;
-Removed the GM-1 from the Ta-152C (which now only has the MW-50);
-Updated the engine temperature parameters on the Tempest V;
-Modified an airfield in Burma;
-Fixed textures in the following cockpits: A-20C; Ar-234; Il-10; MiG-9; Ta-183; Yak-15; Yak-3R; Pe-2 84th Series;
-Modified air-to-air AI on the Ar-234;
-Fixed the bug when hits on the Ar-234’s #1 engine set #2 on fire;
-Modified G4M1 flight model;
-Protected fuel tanks on the J2M and La-5;
-Modified the propeller on the N1K2-Ja;
-Fixed the altitude indicator on The J2M5;
-Fixed the landing gear indicator on the He-162.
Also:
The server can now check for changes on the client-side game modules, i.e. ensure the modules were not modified. To enable the check, a new key was added to the conf.ini file.
In order to set the client-side verification parameters you will need to manually edit the conf.ini file located in your main game folder before launching the game. Open the file with a text editor, find the [NET] section and in the checkRuntime = line write in either 0 or 1 (or 2), then save the file. If the checkRuntime = line does not exist in your conf.ini file, add it to the end of the [NET] section.
checkRuntime=0-no check is made (default);
checkRuntime=1-quick check;
checkRuntime=2-comprehensive check.
NOTE: during the comprehensive check, if the client runs a different OS version from the client, the check may identify the OS differences as changes in game modules.
New maps:
Desert Online: Ian Boys, Vladimir Kochmarsky, Ray Grützmacher, Laurent Cunin
Italy Online: Jörg Wiedemann, Ray Grützmacher, Laurent Cunin
Norway: Ian Boys, Laurent Cunin, Kjetil Aakra
Murmansk Summer: Vladimir Kochmarsky, Ian Boys
Airbase Restriction:
Please note that Herdla on the Norway Map is a fighter base which based aircraft up to the Bf-110 only. When using large flights of aircraft, only planes of the Bf-110 size or smaller will take off successfully.
README
v.4.08
Warning
Corrections:
-Modified the MG42;
Also:
New maps:
- 32_Mariocar
- Engrenado
No SimHQ Forums postaram esse link para baixar, mas acho que é para a versão Russa. Alguém tem alguma informação?
http://files.games.1c.ru/il2pict/408m.exe
- 07_Phantom
Re: Path 4.08
Xiiiiiiiii espero que tenha implementado isso corretamente, isso costuma ser uma fonte enorme de problemas em outros jogos.32_Mariocar wrote: In order to set the client-side verification parameters you will need to manually edit the conf.ini file located in your main game folder before launching the game. Open the file with a text editor, find the [NET] section and in the checkRuntime = line write in either 0 or 1 (or 2), then save the file. If the checkRuntime = line does not exist in your conf.ini file, add it to the end of the [NET] section.
- 32_Mariocar
- Engrenado
- 36_Killer-Ants
- 32_Mariocar
- Engrenado
- 32_Mariocar
- Engrenado
Liberados os paths inclusive o 4.08 Patch + Dedicated Server, no site da Ubi.
- 32_Mariocar
- Engrenado
- 32_Mariocar
- Engrenado
- 32_Mariocar
- Engrenado
