Path 4.08
- 03_Vingador
- 32_Mariocar
- Engrenado
Tenta esse, dica do =BLW=Klein, estou baixando a 151 Kb/s
http://games.internode.on.net/filelist. ... tails=5535
Hades
Re: Path 4.08
O que isso quer dizer? o que é checkruntime???? :-?07_Phantom wrote:Xiiiiiiiii espero que tenha implementado isso corretamente, isso costuma ser uma fonte enorme de problemas em outros jogos.32_Mariocar wrote: In order to set the client-side verification parameters you will need to manually edit the conf.ini file located in your main game folder before launching the game. Open the file with a text editor, find the [NET] section and in the checkRuntime = line write in either 0 or 1 (or 2), then save the file. If the checkRuntime = line does not exist in your conf.ini file, add it to the end of the [NET] section.
checkRuntime=0-no check is made (default);
checkRuntime=1-quick check;
checkRuntime=2-comprehensive check.
NOTE: during the comprehensive check, if the client runs a different OS version from the client, the check may identify the OS differences as changes in game modules.
Wolfxx
Este parametro "checkRuntime" só tem relevância para o HOST, para que verifique (ou não) se os clientes (os jogadores) tem arquivos do game alterados (hackeados, ex. vídeos do Mig3 VTOL, TIR 6DOF...).
Voce não tem que fazer nada no seu config.ini
Sokol1Also:
The server can now check for changes on the client-side game modules, i.e. ensure the modules were not modified. To enable the check, a new key was added to the conf.ini file.
In order to set the client-side verification parameters...
- 36_Killer-Ants
