Como o FOV do IL2 é dividido em 12 posições, é preciso associar teclas para cada uma delas:
Download:
http://forum.sukhoi.ru/attachment.php?a ... 1193994209
Readme:
http://forum.sukhoi.ru/attachment.php?a ... 1194167247
I have track IR4 as well and eventually got the combination to work (I forgot to set up the FOV keys in game to match the program).
I start Track IR, then start Zoom tracker.
I used the "Key repeat" option with two random (un-assigned in game) keys and I disable the back region option. When you load up your game go to your control options and for the two options "increase FOV" and "Decrease FOV" set up the same two random previously un-assigned keys that you used in the Zoom tracker options and you should be set to go.
Works brilliantly I might add.
Como estavam com dificuldade de baixar do AviaForum, baixei e instalei aqui para testar e dei up para eles.I used it for several hours last night with my TIR4 and had no trouble. I believe I have the latest driver, I try to keep up with that stuff. Don't forget that you have to assign the keys to the FOV settings in game. Also, you have to start TIR first, then zoom tracker, it won't work the other way around.
