Também mexeram na AI: Num dos capítulos do jogo, na captura de Saint Saveur, os alemães não ficaram mais esperando serem atacados, lançaram uma cortina de fumaça e aproveitaram para avançarem.
Tem vários, é só escolherem. Seguem os links:
http://www.moddb.com/mods/rendrocs-warzone
http://mjc1975.googlepages.com/home
Advanced Squads for the Tactical Player
Single Player and Multiplayer Mutators for Brothers In Arms
Description:
The Command Mod adds more commands to provide more strategic options
for defeating the enemy.
Rendroc's Enhanced Squad Command Interface for Single Player has a
New Command Ring, Smoke Grenades, Easier Targeting in Authentic Mode,
Assault Cam, Peek Cam, Fall Back, Widen Formation, Man MG, Pick Up
Panzerfaust, Assault Tank, Waypoints, Maneuver Under Cover, Enhanced
Cover AI, and Order Grenades
Dangerous AI adds movement ability to the enemy. They will now attempt
to flank, manuever, and retreat.
WarZone brings many more soldiers from both sides into the battle.
Fighting is more chaotic and intense.
DemonicMP lets you play against (and with!) the computer in Multiplayer.
AI Players will fill empty slots in your created server and will
work to achieve the objectives for their team just as a human player would.
WarZoneMP adds up to 20 more AI-controlled soldiers to Multiplayer battles.
Used with DemonicMP, you can enjoy epic Multiplayer battles never seen
before in Brothers in Arms.
WZGravity changes the physics slightly for projectiles and dead or dying
bodies for a more realistic effect.
RealSights enables a much more realistic view through iron sights and
scopes. Sway has been changed dramatically, aiming is less frustrating,
and you will be able to feel the weight of the weapon as you switch targets.
HollywoodFX enhances all of the impact and explosion effects in the game
and adds new ones, further heighting the atmosphere of fear and danger.
BodyCount keeps dead bodies from vanishing.
RealTracers eliminates tracer fire from rifles and submachine guns and
has an improved tracer appearance for machine guns.
DeadlySquadsMP improves the accuracy for the player-controlled squads
in multiplayer, making the game more strategic as in the single player
game.
CustomWeapons gives you control over the properties such as damage and
sway for every weapon in the game.
CustomMutators will automatically load all of your favorite WarZone
mutators so that you don't have to select each one manually.
NoHUD removes the hud and overlays to give you a more realistic view.
Soundtrack plays the original music in-game as it was intended by the
composer.
GermanSmoke gives the Germans the ability to use smoke grenades.
The Online Recon Mutator will monitor for online games while you play
Single Player games. If a multiplayer server opens up on the
Internet, you will automatically be notified in-game. New Menu
Options are added to make it quicker to join an online server.
Updates:
v4.29: Fixed Order to Pickup Panzerfaust not working
Fixed oddly-posed Germans at end of Buying the Farm
Removed Zoom With Iron Sights with jmoneyWeapons
