Instructions for editing the resource game. (Modding)
So, as I am often asked how I got to the play of textures, as I edited them and checking them, I decided to write a short statement:
Attention! Everything you do - you do at your own risk. Please, before you change anything in the resource game read Important notice of Elijah (a spoiler):
Before discussing the patch, I want to talk about fashions. First, the data that you have access, never intended to hide from the user. Our general plans for the SDK and polzovateleskie fashion and stuff just for it hoped it. We just planned to open it all by yourself when you're ready SDK, but our fans-yourselfers, might not be without help from former or current developers have found a way to do it sooner. The only one with this problem - no user-friendly interface for working with the modes, especially online.
Most importantly, there is a vesh as Valve Anti-Cheat. Steam has the standard functions that run on servers, and we have some of our own additional checks. All this does not lead to Ilovskomu mnogvennomu server kiku. Instead, it is collecting data and analyzing the results, which will eventually lead to massive Banu criminals, which they cut off the multiplayer for their account on each server Bob.
Thus, although many of you can play with FM and other parts of the game, please do so offline. We have not included the interface to switch between the modified and standard files, or user interface for servers to enable / disable custom content. We will probably ignore any violations to date, but will become more aggressive in the coming days. Please keep in mind. Over time, will be Bartholomew's night with a wave of online ban. Criminals will be banned at the same time, without notice or further mercy. If you do not want to make an example out of you, please do not use the modified files online.
1. Download the archive:
il2cod_sfsmod11.zip
http://www.sukhoi.ru/forum/attachment.p ... 1306573446
2.Extract and
- Kegetys.dll copy in a folder ... \ Steam \ SteamApps \ common \ il-2 sturmovik cliffs of dover
- In the same folder, open notepad and enter Launcher.exe.config after row
<maddox.Properties.Settings>
<setting name="nativeDLL" serializeAs="String">
<value> parts \ core \ steam_api.dll </ value>
</ Setting>
Following lines:
<value> kegetys.dll </ value>
</ Setting>
You should get something like:
<applicationSettings>
</ Setting>
</ Setting>
</ Maddox.Properties.Settings>
</ ApplicationSettings>
Then create a shortcut to Launcher.exe, open its properties and appends the path to the EXE file option-dump ... I got something like this:
"C: \ Program Files (x86) \ Steam \ steamapps \ common \ il-2 sturmovik cliffs of dover \ Launcher.exe"-dump
Starting the game with this shortcut, start the mission with which we wish to obtain resources, wait until loaded all the textures come out of the game.
In the folder: (in my case)
folder appears _dump resource games.
In particular (for example) the texture of the earth (which is visible when you stand on the ground) are at
C: \ Program Files (x86) \ Steam \ steamapps \ common \ il-2 sturmovik cliffs of dover \ _dump \ $ bob \ textures \ Terrain \ Detail
Others in other places ... looking for .. easy to find.
In order to test the changes you made:
Create another shortcut with the parameter launcher.exe-mod = testmod
I look like this:
"C: \ Program Files (x86) \ Steam \ steamapps \ common \ il-2 sturmovik cliffs of dover \ Launcher.exe"-mod = testmod
In the folder il-2 sturmovik cliffs of dover (where folder _dump) create a folder testmod to copy the files you modified while preserving the hierarchy of the way ..
For example you have changed the file: back_0.bmp, which is here:
'_dump \ $ Core \ gui \ background \ back_0.bmp'
To see it in the game you must copy it to
'Testmod \ $ core \ gui \ background \ back_0.bmp'
And run the game with the last one you created the shortcut ...
3. To edit a file with the textures you'll need Adobe Photoshop and plugin from Nvidia
http://developer.nvidia.com/nvidia-text ... g9YDwBrraA
More brains, hands and free time.
When you copy these instructions, please specify source:
This article belongs to and is written for users sukhoi.ru
