Resumo da ópera: aumento de 3x no FPS tweakizando.Computador: Corei7 920 over-clocked @4GHz, Radeon HD6870, 12GB RAM at 1920x1280 rez.
ATI users take note.....There is some stuff about the Radeon clock speeds which I won't go into here as you need to read them for yourself to fix a bug with them-the frames below are with the bug fixed using ATI tray tools to lock the clocks.
1. Stock frames with settings 'High' with forest to 'low', texture qual to 'original', grass disabled, AA, AE, SSAO and Vsync all to 'off' - frames 13/54/117
2. Stock frames with everything maxed out 'very high' but grass 'off' - frames 7/46/107
3. As 2 above with AA turned off in game but turned on in graphics card control panel 8x - frames 10/51/117
4. As 3 above with Vsync off in game but on in graphics card control panel - frames 13/52/119
5. As 4 above with texture in game changed from 'high' to 'original' - frames 15/52/117
6. As 5 above but with AF enabled in the graphics card control panel set to 8x instead of application controlled. - frames 19/58/145
7. As 6 above but with the cards AF set to 4x. - frames 21/63/144
So as you can see the minimum frames have gone from the stock 7 to 21 and average 46 to 63.
Se bem que 21 FPS é osso, e o micro usado no teste não é tipo "Casas Bahia"...
