Atenção ao "no respawn" (no estilo das SE do Warbirds) - morreu, "tá morto".
Sokol11st Multisquad Campaign Battle of Britain
5./JG27 & 9./ZG26 Presents:
Battle of Britain Multi squad Campaign STARTS 30th October and runs every sunday at 21:00 CET (15:00 Eastern) for four weeks.
Version will be latest beta patch 2 plus hotfix.
Introduction:
We are looking for Squadrons and Staffeln to take part in our proposed BoB MS Campaign. If you are not part of a Squadron try approaching one to fly with, passwords will only be given to Squadron commanders. We will start at Kanalkampf and run through Adlertag, Adlerangriff and Blitz. We aim to run this campaign over four weeks, one mission per week. We want a historical atmosphere not a bunch of lone wolfs trying to get as many kills as possible! If you don't take enough fuel or waste your ammo there is no respawning, you land, the end!
Scope and Objective:
Aircraft, ground units and mission objectives will all have realistic historical feeling, for example pilots will only have one life per mission! Targets will be historical for example, Shipping, RADAR, Airfields and industrial facilities. Flights will be as long as necessary. Overall the objective is to have a realistic feel, with large scale engagements rather than just a few aircraft fighting ... Its also important that we all have fun!
Realism Settings - Difficulties:
All difficulties will be on except Anthrophermofic.
The server will be scripted so after 15 minutes you will no longer be able to spawn. Hopefully you will have no problem spawning but if you do you will have 15 minutes to find a good spawn, after this period no one will be able to respawn. This will be 15 minutes after the server starts NOT 15 minutes after you join.
Custom Skins:
To improve the server and client performance only default skins will be used! Do not use custom skins or your unit will be expelled from the campaign!
Unit Placement:
Staffeln or Squadrons will be assigned a start position based on historical unit placement depending on map, those with the actual unit name will be placed there automatically and other units assigned at random. Its important you spawn in you designated airfield to avoid collisions and or griefing and generally bringing your unit into disrepute.
AI Aircraft:
Although we welcome bomber crews unfortunately they are a breed apart and fewer in number. Bomber crews are VERY welcome however we will have AI bombers to perform missions during the campaign.
Communication:
Commanders of Staffel or Squadron please sign up here so we can send passwords via PM.
Sign Up Below, Copy Paste and Delete as Appropriate:
Sign Up - Unit Commanders Only:
Commanders Call Sign:
Unit Full Name:
Unit Tags:
Axis or Allied:
Website URL:
Minimum Expected Turn Out:
Average Expected Turn Out:
Pilots "on paper" (Total Pilots):
Willing to take Public Players?: Yes / No
Preferred Aircraft:
