De forma geral tem vaga pela Luftwaffe.
Os eventos são "uma decolagem, uma vida".
Não tem IA e note-se que não a informação prévia sobre o cenário, onde estão os alvos etc. então vôos de reconhecimento são mandatórios.
Sokol1AIR WAR SCENARIO
OBJECTIVE
All bases destroyed OR not enough A/C to field full team, whichever occurs first.
AIRCRAFT
RED – 40 Hurricanes/60 Spitfires
50 Blenheims
BLUE – 40 E1s /10 E3s /40 E4s /10 G.50s
30 Ju88s and He111s/ 10 Me110s / 10 Stukas
NON AIRCRAFT ASSETS
10 ships
2 factories
5 bases
100 flak guns – 70 3.7in - 88mm/30 bofors-40mm
REWARD/COST
Ships – 2 day journey 50/25
A/C – 10
Factories – 50/500
Bases - 0/250
Heavy Flak – 0/2
Light flak – 0/4
RULES
Each mission will be conducted in a 2 hour time allotment.
The mission area is AN27 to BI14. Any intentional flight outside these boundaries is prohibited. Discovery of cheating will result in the banning of that pilot for the remainder of the campaign and the automatic deduction of 5 aircraft of the type flown by the offender from his team’s force pool.
Any object placed is fixed until destroyed or disbanded. Disbanding does not recoup the cost, simply allows replacing of that object (flak/factory/base) at cost at another location.
Bases and factories are destroy-able but they regenerate if not completely knocked out during a mission to simulate repairability.
Any aircraft not landed at a friendly airfield by the completion of the mission time is considered lost and is not returned to your aircraft pool. A “player X has landed” or a “player X has returned to base” message is required and each commander will post a link to his team’s stats in his AAR as a backup to mission claims. If a posted report is not available to confirm a pilot’s safe RTB, should it come into question, his aircraft will be considered missing in action and will not be returned to the pool unless further clarification is given in a timeframe TBD. Any attempts to cheat and claim a successful return to base by landing at an enemy airfield will be punished per the out-of-boundary flight rule.
No re-fly is allowed. One life per mission. Only exceptions are accidents prior to wheels-up/ground accidents. Any malfunctions, CTDs, and mishaps that occur once you are off the ground and your gear are up do not qualify for a refly.
All aircraft skins must be of a historical nature. In-game markings must be turned on.
Replacement points cannot be used to increase an item number beyond the starting pool quantity. Replacement points can be hoarded or spent according to the desires of the respective commanders. Any changes will be made immediately after the mission is complete and stats are confirmed.
Each team will only have 100% intelligence knowledge of their own force status. A message will be displayed to confirm the destruction of an airfield or factory to confirm its status at the time of the trigger. It is up to the intelligence office of either team to track progress towards their objectives. Identifying screenshots will be posted to both sides so that target identification can be readily achieved by recon flights and all targets will use the same templates. Screenshots of destroyed targets and the respective on screen messages are encouraged to back up the admin efforts.
Both teams will have radar with the same capabilities with a hard-deck for detection. “Observer Corps” on both sides will be able to report on contacts below that altitude over friendly territory and will also provide identification of the aircraft types.
Ships will be placed at a friendly port and sent on a 2 mission length track towards another friendly port on the map. The 50 points for their arrival will be awarded upon their survival of their 2nd mission at sea in the vicinity of their destination port.
http://sowc.forumotion.co.uk/t226-new-c ... rting-soon
