Portanto "Luftwhiners" não é um problema relacionado só com o 20mm do BF 109, é com qualquer munição HE.
Team Fusion Hotfix 4.312 now Available
TF 4.312 READ ME
Explosive ammo shrapnel
Fixed typo that was making the shrapnel more deadly than normal. After the fix, it will behave like in 4.0.
Sounds
Corrected the distorted Jumo engine sounds.
Sandbags
Sandbags now look like sandbags again.
He-115
He-115 erratic flight behaviour corrected.
Flight Model Changes
Bf-109's
109E-1/E-1b/E-3/E-4/E-4N and E-4N De-rated supercharger performance improved over 6000 meters.
Bf-110's
Bf-110's aerofoils slightly changed to provide more lift.
Heinkel 111H and 111P
Heinkel 111's engines, aerofoil, climb, and speed completely revised.
Junkers Ju-88A
Ju-88A engines, aerofoil, climb, and speed completely revised.
Junkers Ju-87B
Junkers Ju-87B overheat and aerofoil adjusted slightly.
Fiat BR20M
Fiat BR20M overheat and aerofoil adjusted slightly.
Fiat G-50
Fiat G-50 overheat adjusted slightly.
Blenheim IV, IVF and IVNF
Blenheim aerofoil and damage modeling adjusted slightly.
Merlin III 100 octane
100 octane Merlin III engines overheat revised.
Fuel Tank Armour
Fuel Tank armour for aircraft equipped slightly improved.
Major Flight Model changes in TF 4.312 see 100 octane Merlin III powered aircraft with better performance from sea level up to Full Throttle Height. (16,250 ft) Conversely, 109's improve over Full Throttle Heights. (4000 m E-1/E-1B, 4500 m E-3/E-4, 4900 m E-4N)
In addition, bombers and attack aircraft are more maneuverable, and Heinkels and Ju-88 climb performance corrected closer to historical.
Get it here:
https://s3.amazonaws.com/TFMOD/TF+MOD+4 ... taller.zip
Para jogadores casuais, melhor esperar uns dias para ver se não a "Efeitos Luthier" digo, colaterais como no 4.3.11.
E não esqueçam de apagar o Cache!
Agora os "winhers" estão reclamando que o 109 pega fogo mais fácil que o Spit.
