Para atacar a frota inimiga, primeiro tem que achar.
E ótimo esse "fog of war" não mostrando quem voa o que.No more AI recon planes. All recon flights must be human. Each team has 8 available recon A/C in total.
Radar or FoW has been decreased. It now tracks aircraft at 2.5 grids radius, and not below 50m. Small ships have simulated visual radius of 1 grid and no altitude limitation.
If you die, you will have to sit out before being given permission to refly. Penalty duration is 7 minutes. Successful bail out doesn't force a penalty. Only pilot death.
Home base icons (carriers) will remain static throughout the Mission, further preventing the one team to locate the other.
A/C type will no longer be visible on the scoring screen.
http://www.battle-fields.com/commscentr ... -Coral-Sea
http://www.battle-fields.com/commscentr ... SFX-V7-0-2
http://www.battle-fields.com/commscentr ... post307840
