As campanhas da Desastersoft são consideradas "hardcore". Foi abatido? Tente de novo, porque se não a campanha... the end.
http://www.desastersoft.com/news
"W.I.P. NEWS!
Dear friends, customers, enthusiasts,
Since December 2013 a new Cliffs of Dover add-on has been in development.
With of course lots off new stuff both in the career mode and missions. One of the features is a totally new career mode in which you start as lowest in rank in your squadron and you needing to work your way up to squadron leader. How much missions you will need to achieve this goal will depend on your skill level and achievements, and the difficulty setting you have selected.
This career game mode is expected to have 150 missions in the long version (planned) of which we have completed and tested 130 missions.
The campaign revolves around 1.Staffel of group I. / JG 26 called the Eagle squadron. The campaign can be played in three different versions:
■Career mode – as described above with probably 150 missions taking place between June 22nd and December 31st 1940.
■Historically – based on the actual operational deployment by group I. / JG 26 with around 70 missions.
■Guided campaign – you will be guided through the massive campaign with deployments to specific timeframes with new aircraft assigned to you.
In addition there will be a Bf 110- and Stuka campaign both, again, in various versions.
Some details about the Stuka campaign.
The Stuka campaign will be a kind of adventure. It won’t be about just smash targets. But also to follow in the footsteps of Stuka ace Oberst Hans Ulrich Rudel. Rudel shot down 9 enemy airplanes in his Junkers 87. You are required to do the same aside the ground targets you need to destroy.
TEAM FUSION support
All campaigns will be available as an EXTRA for TEAM FUSION fans/members.
They include the by TEAM FUSION provided autumn- and winter maps, various sub-versions of the aircraft used and a historical campaigns set in the year 1941. Once all relevant aircraft types are created and ready, a TEAM FUSION release can be expected. Together with TEAM FUSION, DESASTERSOFT will be heading off into the year 1941!
The add-on CHANNEL BATTLES - LUFTWAFFE will be available as download, starting end of August.
Added to the series will be CHANNEL BATTLES – ROYAL AIR FORCE set available as a single download.
Following the above releases we will be offering a special collector’s edition box called SONDEREDITION. It will containing the two add-ons CHANNEL BATTLES – LUFTWAFFE and CHANNEL BATTLES – ROYAL AIRFORCE a war map and a printed manual. But this Box is in german only!
We hope you have some patience left while waiting in great anticipation for this release."
Um "perrengue" chato para os "singleplayers" é o fato da AI do CloD ignorar o jogador se ele é o lider do grupo.
O "workaround" é ativar o "autopilot" momentaneamente no início da missão - isso faz com que a Torre e os outros aviões "vejam" o jogador. O TF promemeu rever a AI no TT 5.0 (2015).
O pessoal da Desastersoft descobriu que se:
Taxiar para a pista.
Solicitar as condições de tempo (TAB -> 7 -> 3)
Pedir permissão para decolagem (TAB -> 7 -> 6) - A resposta vem negativa, algum russo inverteu os scripts, portando ignore e siga em frente.
Decolar
Entre no circuito de trafégo para a direita, aguardando as AI (nr.2,3,4..) entrarem em formação.
Bingo, a AI nota que voce é um lider disciplinado (e não decola, mantem 100% e segue em frente em linha reta
Outro dia vi um coisa curiosa no CloD, 4 AI (2 amigas, 2 inimigas) entram num círculo, cada uma tentando pegar o 6! da outra.
BTW - No BoS as vezes acontece se decolar "apressado" a AI empaca e não sai do chão... Também se não seguir os waypoints a risca, não atacam os alvos.
E, para quem torce o nariz para "SP", este mercado é umas tres ou quadro vezes maior que o MP, portando essencial para a sobrevida do genêro.
