Resolvi documentar a instalação do LOMAC e o Flaming Cliffs, mais as campanhas, mods de cockpit, texturas e muito mais... O simulador ficou outro e estou muito impressionado!
Ai vai meu checklist. Recomendo enfaticamente todos os mods listados:
Baixei a maioria do www.lomacfiles.com - um excelente site.
- OK Back Up das campanhas velhas/ LOMAC 1.02 e LOMAN 2.1
OK LOMAC 1,0
OK Flaming Cliffs serial number
OK Seasonal Pack
OK Movies pack
OK LOCK ON: Flaming Cliffs v. 1.1 - LO 1.1 REG SAVE UNINSTALLER (setupfix)
OK LOCK ON: Flaming Cliffs v. 1.1 - GROUND UNITS LODs FIX
OK Reg Saver
OK HL Lockon (skin)
OK Zzzspace sound pack V1 for FC 1.1 (instalação manual)
1. Manually BACKUP the original Flamming Cliffs ‘Sound’ folders, then MANUALLY DELETE EVERY FILE within both the ‘SOUNDS’ and the ‘EFFECTS’ folders - you must remove those files or else the .wav replacements will not work. (Note: wav files are used rather than .ogg for better in-game fps performance)
2. Download and MANUALLY EXTRACT the downloaded zip file’s contents: zzzspace_v1_for_lomac_flaming_cliffs_manual_instal l.zip This will create the full folder structure path containing all of the relevant files of this sound mod.
3. Copy and paste the new soundpack’s files into these folders as indicated by their locations by the unzipped folders. When you are done all of the files within both the ‘Sounds’ and the ‘Effects’ folders will have been 100% replaced.
4. Now place the extracted files into their relevant folders in Flaming Cliffs,
5. Lastly, make sure that you set your in-game ‘Audio options’ precisely like this (or else you will get other than the intended result – these are not the same as in previous sound packs)
MASTER VOLUME = 100% (or a setting to balance with multiplay voice comms)
MUSIC = 25%
RADIO = 50%
ENGINES = 100%
MECHANICALS = 100%
EFFECTS = 100%
WIND = 100%
WARNING = 50%
COCKPIT = 90%
OK Instalado o LOMAN 4.0 b3
OK Instalado os dlls msvr71 e atl71 (senão não funciona - biaxar na net) - A partir daqui todos os instals via LOMAN mesmo.
OK Lostsoul campaign
OK Mig-29S campaign
OK Ukraine Freedon
OK Red october campaign (1.02 até aqui)
ok hogsfly
OK May 0505 Su25t Holdback
OK SU25T adler campaign
OK TakeDown
OK Two Day War mig-29S
OK OP PHoenix Su-33/Operation Liberty Part 1 e 2/SU-33 Operation Zodiac (descompactado o .RAR e movido para o diretórios de missions/campaigns.
(each skin has its skin code so you know were they will install - all have been tested and when needed, a new Loman 2.x pack was made)
Quote:
MiG-29 Fulcrum web page
Su-27 Flanker web age
Su-33 Flanker web page
F-15 Eagle web page
A-10 Hog web page
The Cockpit guide
the A-10 guide
OK A-10 Cockpit liftlines by Soul DOWNLOAD IT
OK+- Blue Cockpit Lights by Mitch Janssen DOWNLOAD IT
OK+- A-10 Cockpit V.2 BY Archer DOWNLOAD IT
OK A-10 Cockpit Gauges by Archer DOWNLOAD IT
OK Kneeboard by Rapier71 DOWNLOAD IT
OK High Res HUD fonts by Oxyd DOWNLOAD IT
The F-15
ok f-15 FULL/RED Cockpit Liftlines by I3eowulf DOWNLOAD IT
OK F-15 Cockpit by Archer DOWNLOAD IT
OK Smooth Canopy Frame by Asromzek DOWNLOAD IT
F-15 Cockpit Gauges by Archer DOWNLOAD IT
NAO F-15 NVG-style cockpit lights by Merlin DOWNLOAD IT
OK Smooth HUD Frame by Azromzek DOWNLOAD IT
(the F-15 uses the same add-ons for HUD fonts and Kneeboard)
The Fulcrum
ok MiG-29A/C FULL/RED Cockpit Liftlines by I3eowulf DOWNLOAD IT
ok MiG-29 Cockpit by Sebastien MHM MHM DOWNLOAD IT
ok MiG-29 Cockpit Gauges by Archer DOWNLOAD IT
The Flanker
OK Su-27 FULL/RED Cockpit liftlines web page by I3eowulf
OK+- Su-27 Cockpit by Sebastien MHM MHM DOWNLOAD IT
OK+- Su-27 Cockpit Gauges by Archer DOWNLOAD IT
And …
ok High Res US Pilot & Seat by Mitch Janssen DOWNLOAD IT
ok Cockpit Reflections
Grande abraço,
