http://snomhf.exofire.net/leftyHOTASdevelopment.html
haja doletas para manter o vício loool
obrigado pela dica Sokol !
O povo do FS vai gostar desta caracteristica, para simular auto-throttle.1, first of all, this is the first force feedback mechanism of induction, much higher than the previous force feedback. For example, the accelerator, if you use the mouse to move the throttle game, then you will X65F With the throttle on the move, he was interactive. That is, the so-called linkage. This is the first in flight controllers.
Original em chines:
比如油门,如果你用鼠标动了游戏里的油门,那么你X65F上的油门也会随着动,他是互相作用的。
也就是所谓的联动。
这是目前飞行控制器里的首创。
